CHANGE_OWNER | Examples |
<CHANGE_OWNER | Attribute
Description Table |
docid ="string" newowner ="string" > No Child Elements </CHANGE_OWNER > | |
Bold: Attribute or child element is
required. |
Attribute | Usage | Back to Top |
docid | String used to uniquely identify a
document. The client used to publish the metadata is responsible for
creating the document ID. This ID is automatically assigned when using
ArcCatalog. If another client is used, GET_UUID can be used to
request a valid ID. The format for an ID is the
following: {HHHHHHHH-HHHH-HHHH-HHHH-HHHHHHHHHHHH} where H is a hexadecimal digit (0-9,a-f,A-F). The ID is limited to 38 characters. | |
newowner | New owner name. Must be a value that you already used when logging in. |
Example 1: | Back to Top |
<?xml version="1.0"
encoding="UTF-8" ?> <ARCXML version="1.1"> <REQUEST> <PUBLISH_METADATA> <CHANGE_OWNER docid="{5289D9C3-55BD-4D58-A9DD-24B40427F943}" newowner="publish" /> </PUBLISH_METADATA> </REQUEST> </ARCXML> |
