RASTER_RANGE  Examples
Used in:  CONFIG
Parent elements:  RASTER_RENDERER
<RASTER_RANGE Attribute Description Table
     lower ="double"
     upper ="double"
     color ="0,0,0 - 255,255,255"  [0,0,0]
     equality ="all | upper | lower | none"  [lower]
     label ="string"  [Value of lower or upper]
     transparency ="0.0 - 1.0"  [1.0]
     No Child Elements
</RASTER_RANGE >
Bold: Attribute or child element is required.
Description:
Restrictions:
Notes:
Attribute Descriptions for RASTER_RANGE:
Attribute Usage Back to Top
color Color using RGB values. Defines the color corresponding to the specified range of index values.
equality Defines the upper and lower bounds of each range. If "all" is used, then lower <= value <= upper. If "upper" is used, lower < value <= upper. If "lower" is used, lower <= value < upper.
label Description to be shown on legend. Valid with HTML Viewers only.
lower Defines the lower value of the range.
transparency Value to set percentage of transparency. 1.0 is 0 percent transparent. 0.0 is 100 percent transparent.
upper Defines the upper value of the range.
Examples for RASTER_RANGE:
Example 1: When in a map configuration file. Back to Top
<?xml version="1.0" encoding="UTF-8"?>
<ARCXML version="1.1">
  <CONFIG>
    <ENVIRONMENT>
      <LOCALE country="US" language="en" variant="" />
      <UIFONT color="0,0,0" name="Arial" size="12" style="regular" />
    </ENVIRONMENT>
    <MAP>
      <PROPERTIES>
        <ENVELOPE minx="-90" miny="-180" maxx="90" maxy="180" name="Initial_Extent" />
        <MAPUNITS units="decimal_degrees" />
        <FILTERCOORDSYS id="4326" />
        <FEATURECOORDSYS id="4326"/>
      </PROPERTIES>
      <WORKSPACES>
        <SDEWORKSPACE name="sde_ws-0"  server="myserver" instance="port:5151" database="" user="sdeuser" encrypted="true" password="LXEMUR" />
      </WORKSPACES>
      <LAYER type="image" name="Land Use" visible="true" id="0">
        <DATASET name="SDEUSER.BIT8_COLORMAP.RASTER" workspace="sde_ws-0" />
        <RASTER_RENDERER>
          <RASTER_EXACT value="0" color="10,200,10" transparency="0.5"  label="Clouds"/>
          <RASTER_RANGE lower="1" upper="101" color="200,40,10" transparency="0.5"  equality="lower" label="Urban"/>
          <RASTER_RANGE transparency="1.0" lower="101" upper="255" color="255,255,10" equality="lower" label="Rural"/>
          <RASTER_OTHER transparency="0.0" label="Other"/>
        </RASTER_RENDERER>
      </LAYER>
    </MAP>
  </CONFIG>
</ARCXML>
