CHANGE_OWNER  Examples
Used in:  REQUEST
Servers:
Metadata (Publish)
Parent elements:
PUBLISH_METADATA
<CHANGE_OWNER Attribute Description Table
     docid ="string"
     newowner ="string"
     No Child Elements
</CHANGE_OWNER >
Bold: Attribute or child element is required.
Description:
    Allows a new owner to be assigned to a document. A document can only be edited by its owner.
Restrictions:
Notes:
Attribute Descriptions for CHANGE_OWNER:
Attribute Usage Back to Top
docid String used to uniquely identify a document. The client used to publish the metadata is responsible for creating the document ID. This ID is automatically assigned when using ArcCatalog. If another client is used, GET_UUID can be used to request a valid ID. The format for an ID is the following:
{HHHHHHHH-HHHH-HHHH-HHHH-HHHHHHHHHHHH}
where H is a hexadecimal digit (0-9,a-f,A-F). The ID is limited to 38 characters.
newowner New owner name. Must be a value that you already used when logging in.
Examples for CHANGE_OWNER:
Example 1: Back to Top
<?xml version="1.0" encoding="UTF-8" ?>
<ARCXML version="1.1">
  <REQUEST>
    <PUBLISH_METADATA>
      <CHANGE_OWNER docid="{5289D9C3-55BD-4D58-A9DD-24B40427F943}" newowner="publish" />
    </PUBLISH_METADATA>
  </REQUEST>
</ARCXML>
