METADATA_DATASET  Examples
Used in:  RESPONSE
Servers:  Metadata (Browse)
Parent elements:  METADATA
<METADATA_DATASET Attribute Description Table
     children ="true | false"
     docid ="string"
     folder ="true | false"
     index_status ="indexed | not indexed | indexing error"
     name ="string"
     owner ="string"
     private ="true | false"
     refcount ="integer"
     siblings ="true | false"
     content ="liveData | downloadableData | offlineData | staticMapImage | document | application | geographicService | clearinghouse | mapFiles | geographicActivities | unknown"
     gnd ="string"
     onlink ="string"
     server ="string"
     service ="string"
     servicetype ="metadata | image | feature | wms"
     thumbnail ="string"
     updated ="string"
     url ="string"
     <ENVELOPE... />
</METADATA_DATASET >
Bold: Attribute or child element is required.
Description:
Restrictions:
Notes:
Attribute Descriptions for METADATA_DATASET:
Attribute Usage Back to Top
children Set to "true" if the dataset has children.
content Metadata document content type.
docid String used to uniquely identify a document. The client used to publish the metadata is responsible for creating the document ID. This ID is automatically assigned when using ArcCatalog. If another client is used, GET_UUID can be used to request a valid ID. The format for an ID is the following:
{HHHHHHHH-HHHH-HHHH-HHHH-HHHHHHHHHHHH}
where H is a hexadecimal digit (0-9,a-f,A-F). The ID is limited to 38 characters.
folder Set to "true" if the document represents a folder.
gnd URL of a GND file on the server pointing to an ArcIMS service referenced by the metadata document.
index_status Determines whether a document is indexed for text searches. If an error has occurred while indexing, "indexing error" is returned.
name Name that identifies the dataset corresponding to the document.
onlink A string identifying the location of the dataset corresponding to the document.
owner Name identifying the owner of the metadata document.
private Set to "false" if the document is viewable by all users. Set to "true" if viewable only by the owner.
refcount Number of times the document is referenced in the hierarchy.
server The URL of the Web server containing data or metadata associated with the document, for example, http://mymachine.domain.com.
service The name of the ArcIMS service containing data or metadata associated with the document.
servicetype Type of ArcIMS service.
siblings Set to "true" if the dataset has siblings.
thumbnail URL of the thumbnail image.
updated Last date metadata record was updated. Format is YYYY-MM-DD hh:mm:ss.
url URL of the XML document being retrieved.
Examples for METADATA_DATASET:
Example 1: Includes the "custom attribute" called approved Back to Top
<?xml version="1.0" encoding="UTF8" ?>
<ARCXML version="1.1">
  <RESPONSE>
    <METADATA numresults="1" startresult="0" total="1">
      <METADATA_DATASET name="metadata" owner="author" docid="{CD4AEFEF-896E-45EC-9A7E-EEBA823370C5}" content="unknown" url="http://mymachine.domain.com/output/OracleMetadata_P375_T437_D18.xml" children="true" siblings="false" private="false" folder="true" index_status="indexed" refcount="1" updated="2002-02-11 14:51:14" approved="Y">
        <ENVELOPE minx="-141.001235918609" miny="41.3912889520516" maxx="-71.2933350698463" maxy="68.6637039277661" />
      </METADATA_DATASET>
    </METADATA>
  </RESPONSE>
</ARCXML>
