PUT_METADATA | Examples |
<PUT_METADATA | Attribute
Description Table |
docid ="string" name ="string" content ="liveData | downloadableData | offlineData | staticMapImage | document | application | geographicService | clearinghouse | mapFiles | geographicActivities | unknown" folder ="true | false" [false] onlink ="string" parentdocid ="string" private ="true | false" [false] server ="string" service ="string" servicetype ="metadata | image | feature | wms" > <ENVELOPE... /> <THUMBNAIL... /> </PUT_METADATA > | |
Bold: Attribute or child element is
required. |
Attribute | Usage | Back to Top | ||||||||||||||||||
content | The values for this attribute
correspond to the content types listed in the drop-down comb box of the
Metadata Explorer.
docid | String used to uniquely identify a
document. The client used to publish the metadata is responsible for
creating the document ID. This ID is automatically assigned when using
ArcCatalog. If another client is used, GET_UUID can be used to
request a valid ID. The format for an ID is the
following: {HHHHHHHH-HHHH-HHHH-HHHH-HHHHHHHHHHHH} where H is a hexadecimal digit (0-9,a-f,A-F). The ID is limited to 38 characters. | |||||||||||||||||||
folder | Determines whether document represents a folder. Use "false" if the document does not contain other documents. Use "true" if the document represents a folder. | |||||||||||||||||||
name | Name that identifies the dataset corresponding to the document. | |||||||||||||||||||
onlink | A string identifying the location of the dataset corresponding to the document. | |||||||||||||||||||
parentdocid | Unique string for identifying a document belonging to the parent name and parent owner. | |||||||||||||||||||
private | Determines whether document is viewable for all users. Use "false" if the document is viewable by all users. Use "true" when the document is viewable only by the document owner. | |||||||||||||||||||
server | The URL of the Web server containing data or metadata associated with the document, for example, http://mymachine.domain.com. | |||||||||||||||||||
service | The name of the service containing data or metadata associated with the document. | |||||||||||||||||||
servicetype | Type of ArcIMS service. |
Example 1: | Back to Top |
<?xml version="1.0"
encoding="UTF-8" ?> <ARCXML version="1.1"> <REQUEST> <PUBLISH_METADATA> <PUT_METADATA name="World" docid="{C64D8F38-82B4-11D5-99C2-000086460FA0}" private="false" folder="true" parentdocid="root" > <ENVELOPE minx="-180" miny="-90" maxx="180" maxy="90" /> <THUMBNAIL>...</THUMBNAIL> <!--<?xml version="1.0"?> <metadata>...</metadata>--> </PUT_METADATA> </PUBLISH_METADATA> </REQUEST> </ARCXML> |
