Using GET_SERVICE_INFO and SERVICEINFO with Image and Feature Services
Introduction
GET_SERVICE_INFO is a request for accessing information about an ArcIMS service such as the environment, properties, and layer information. This information is returned in a SERVICEINFO response. This document covers Feature and Image Services. For information on ArcMap Image Services, see Using GET_SERVICE_INFO and SERVICEINFO with ArcMap Image Services.
The following map configuration file, started as an Image Service, is used for the GET_SERVICE_INFO examples in this document. The file consists of two layers from the ESRIDATA data set and an acetate layer. The following table summarizes the layer names, file name, file type and layer ID number.
Layer NameData NameData TypeLayer ID
BackgroundWORLD_IMG.gifImage0
CountriesCNTRY94Polygon1
northarrowNoneAcetatenortharrow
Map configuration file used with the GET_SERVICE_INFO requests that follow:
<?xml version="1.0" encoding="UTF-8"?>
<ARCXML version="1.1">
  <CONFIG>
    <ENVIRONMENT>
      <LOCALE country="US" language="en" variant="" />
      <UIFONT color="0,0,0" name="Arial" size="12" style="regular" />
      <SCREEN dpi="96" />
    </ENVIRONMENT>
    <MAP>
      <PROPERTIES>
        <ENVELOPE minx="-180.0" miny="-90.0" maxx="180.0" maxy="90.0" name="Initial_Extent" />
        <MAPUNITS units="decimal_degrees" />
      </PROPERTIES>
      <WORKSPACES>
        <IMAGEWORKSPACE directory="<path to data>" name="jai_ws-4" />
        <SHAPEWORKSPACE name="shp_ws-5" directory="<path to WORLD ESRIDATA>" />
      </WORKSPACES>
      <LAYER type="image" name="Background" visible="true" id="0">
        <DATASET name="WORLD_IMG.gif" type="image" workspace="jai_ws-4" />
      </LAYER>
      <LAYER type="featureclass" name="Countries" visible="true" id="1">
        <DATASET name="CNTRY94" type="polygon" workspace="shp_ws-5" />
        <SIMPLERENDERER>
          <SIMPLEPOLYGONSYMBOL filltransparency="0.0" boundarywidth="2"/>
        </SIMPLERENDERER>
        <EXTENSION type="Extract">
          <EXTRACTPARAMS clip="true">
            <OUTPUTFILE file="world">
              <OUTPUTFIELD name="NAME" alias="Country" />
            </OUTPUTFILE>
          </EXTRACTPARAMS>
        </EXTENSION>
        <EXTENSION type="Geocode">
          <GCSTYLE name="SingleField">
            <GCFIELD id="KeyField" name="NAME" />
          </GCSTYLE>
        </EXTENSION>
        <EXTENSION type="StoredQuery">
          <STOREDQUERIES>
            <STOREDQUERY name="Country">
              <QUERY where="( NAME = [%var%] )" subfields="#SHAPE# AREA NAME ABBREVNAME FIPS_CODE WB_CNTRY" />
              <SQVAR position="0" name="[%var%]">
                <FIELD name="NAME" precision="0" type="12" size="40" />
              </SQVAR>
            </STOREDQUERY>
          </STOREDQUERIES>
        </EXTENSION>
      </LAYER>
      <LAYER type="acetate" name="northarrow" id="northarrow">
        <OBJECT units="pixel">
          <NORTHARROW type="6" size="40" coords="60 80" shadow="32,32,32" angle="0" antialiasing="True" overlap="False"/>
        </OBJECT>
      </LAYER>
    </MAP>
  </CONFIG>
</ARCXML>
The Background layer is an image of the world. The Countries layer contains country boundaries and includes three extensions: one for extract, one for geocode, and one for stored queries. The acetate layer consists of a north arrow. The map in the following figure is example output using this service.
Default Image
GET_SERVICE_INFO Framework
A GET_SERVICE_INFO request requires only the GET_SERVICE_INFO element as shown in the example below.
GET_SERVICE_INFO request:
  <REQUEST>
    <GET_SERVICE_INFO evelope="true" fields="true" renderer="true" extensions="true" />
  </REQUEST>
</ARCXML>
SERVICEINFO Framework
Depending on which attributes are used with GET_SERVICE_INFO, all or a subset of information about the Image or Feature Service is returned in SERVICEINFO. By default, SERVICEINFO returns all information about a MapService. Based on the above request on the sample service, the following example shows the SERVICEINFO response.
SERVICEINFO response:
<?xml version="1.0" encoding="UTF8"?>
  <RESPONSE>
    <SERVICEINFO>
      <ENVIRONMENT>
        <LOCALE language="en" country="US" />
        <UIFONT name="Arial" color="0,0,0" size="12" style="regular" />
        <SEPARATORS cs=" " ts=";"/>
        <SCREEN dpi="96"/>
        <IMAGELIMIT pixelcount="1048576" />
      </ENVIRONMENT>
      <PROPERTIES>
        <ENVELOPE minx="-180" miny="-90" maxx="180" maxy="90" name="Initial_Extent" />
      </PROPERTIES>
      <LAYERINFO type="image" name="Background" visible="true" id="0">
        <ENVELOPE minx="-180" miny="-89.9747543334961" maxx="179.9423828125" maxy="90" />
      </LAYERINFO>
      <LAYERINFO type="featureclass" visible="true" name="Countries" id="1">
        <FCLASS type="polygon">
          <ENVELOPE minx="-180" miny="-90" maxx="180" maxy="83.5960388183594" />
          <FIELD name="AREA" type="8" size="12" precision="3" />
          <FIELD name="NAME" type="12" size="40" precision="0" />
          <FIELD name="ABBREVNAME" type="12" size="12" precision="0" />
          <FIELD name="FIPS_CODE" type="12" size="2" precision="0" />
          <FIELD name="WB_CNTRY" type="12" size="3" precision="0" />
          <FIELD name="#SHAPE#" type="-98" size="0" precision="0" />
          <FIELD name="#ID#" type="-99" size="16" precision="0" />
        </FCLASS>
        <SIMPLERENDERER>
          <SIMPLEPOLYGONSYMBOL filltransparency="0.0" boundarywidth="2" />
        </SIMPLERENDERER>
        <EXTENSION type="extract">
              <OUTPUTFIELD name="NAME" alias="Country"/>
            </OUTPUTFILE>
          </EXTRACTPARAMS>
        </EXTENSION>
        <EXTENSION type="Geocode" >
          <GCSTYLE name="SingleField" />
        </EXTENSION>
          <STOREDQUERIES>
              <QUERY subfields="#SHAPE# AREA NAME ABBREVNAME FIPS_CODE WB_CNTRY" where="( NAME = [%var%] )" >
              </QUERY>
              <SQVAR name="[%var%]" position="0">
                <FIELD name="NAME" type="12" precision="0" size="40" />
              </SQVAR>
            </STOREDQUERY>
          </STOREDQUERIES>
        </EXTENSION>
      </LAYERINFO>
      <LAYERINFO type="acetate" name="northarrow" visible="true" id="northarrow"/>
    </SERVICEINFO>
  </RESPONSE>
</ARCXML>
SERVICEINFO is divided into three sections: ENVIRONMENT, PROPERTIES, and LAYERINFO.
ENVIRONMENT
ENVIRONMENT takes its values from the Image or Feature service or assigns default values. LOCALE and UIFONT are required, so the information in SERVICEINFO is always taken directly from the service. With SCREEN and SEPARATORS, the values are either those assigned in the service or default values assigned by the ArcIMS Spatial Server. For SCREEN, the default value for dpi is "96". For SEPARATORS, the default for cs (coordinate separator) and ts (tuple separator) are a space and semicolon, respectively.
IMAGELIMIT is always included and is set when an Image Service is started. By default, an image is limited in size to 4 MB, which corresponds to 1,048,576 pixels. Changes can be made to the image size and pixel count using the ArcIMS Administrator. For more information, see Using ArcIMS. The attribute pixelcount reports the pixel count from the ArcIMS Administrator, but it cannot be changed using GET_SERVICE_INFO.
CAPABILITIES is included only when forbidden elements are added to an access control list (ACL). The ACL file is used for user authentication to grant users access to specific Image or Feature Services. One way to limit access is to forbid one or more of the requests: GET_EXTRACT, GET_FEATURES, GET_GEOCODE, GET_IMAGE, GET_SERVICE_INFO, GET_LAYOUT, GET_RASTER_INFO, GET_METADATA, or PUBLISH_METADATA. For more information on forbidden elements, see "ArcIMS Servlet Connector" under the System Administration chapter in the ArcIMS Help.
In the example below, forbidden in CAPABILITIES is set to GET_GEOCODE and GET_EXTRACT. This means no requests with GET_GEOCODE or GET_EXTRACT will be processed.
ENVIRONMENT and its child elements:
<ENVIRONMENT>
  <CAPABILITIES forbidden="GET_GEOCODE,GET_EXTRACT"/>
  <SCREEN dpi="96"/>
</ENVIRONMENT>
PROPERTIES
PROPERTIES in SERVICEINFO repeats back all information in the PROPERTIES section of an Image or Feature Service. The ENVELOPE for the service is always included since it is required in a service. Two ENVELOPEs may be in the response if both name="Initial_Extent" and name="Extent_Limit are included. All other child elements are optional in a service and are in the SERVICEINFO response only when included in the service. Optional child elements valid in both Feature and Image Services include MAPUNITS, FEATURECOORDSYS, and FILTERCOORDSYS. Optional child elements valid in Image Services only include BACKGROUND, LEGEND, IMAGESIZE, and OUTPUT.
PROPERTIES and its child elements:
<PROPERTIES>
  <FEATURECOORDSYS id="54030" />
  <FILTERCOORDSYS id="4326" />
  <MAPUNITS units="meters" />
  <LEGEND autoextend="true" backgroundcolor="255,255,0"/>
  <BACKGROUND color="0,0,255" />
  <IMAGESIZE width="480" height="640"/>
  <OUTPUT path="c:\arcims\website" baseurl="http://mycomputer.domain.com/website"/>
</PROPERTIES>
LAYERINFO
LAYERINFO describes the layer information in a service and includes the layer type, name of the layer, whether the layer is visible, the layer ID, and the minimum and maximum scales at which the layer can be displayed. All these parameters are defined in the service LAYER. None of these parameters can be overridden in a request.
There are three LAYERINFO types, each of which corresponds to the same LAYER type in a map configuration file. The following example shows each of the layer types with the minimum required information.
LAYERINFO and minimum returned information:
</LAYERINFO>
  <FCLASS type="polygon"> </FCLASS>
</LAYERINFO>
GET_SERVICE_INFO Attributes
GET_SERVICE_INFO has five optional attributes, four of which determine what information about a featureclass layer is returned in SERVICEINFO. The fifth attribute is dpi, which is discussed later in this session.
If the above attributes are set to "false", the minimum amount of information about featureclass layers is returned.
GET_SERVICE_INFO request setting attributes false:
  <REQUEST>
    <GET_SERVICE_INFO envelope="false" fields="false" renderer="false" extensions="false"/>
  </REQUEST>
</ARCXML>
When all the attributes are set to false in GET_SERVICE_INFO, the SERVICEINFO response returns the minimum amount of information for LAYERINFO. The ENVIRONMENT and PROPERTIES elements return the same information regardless of whether the attributes are true or false.
SERVICEINFO response with ENVELOPE:
  <RESPONSE>
    <SERVICEINFO>
      <ENVIRONMENT>
        <SCREEN dpi="96"/>
      </ENVIRONMENT>
      <PROPERTIES>
      </PROPERTIES>
      </LAYERINFO>
        <FCLASS type="polygon"></FCLASS>
      </LAYERINFO>
    </SERVICEINFO>
  </RESPONSE>
</ARCXML>
Envelope attribute
When envelope is set to true, the extent for each featureclass layer is included. This information is in addition to the extent of the service as a whole. The extent is always returned for image layers and no extent is included for acetate layers.
GET_SERVICE_INFO request using envelope:
  <REQUEST>
    <GET_SERVICE_INFO envelope="true" fields="false" renderer="false" extensions="false"/>
  </REQUEST>
</ARCXML>
In the SERVICEINFO response, an ENVELOPE is included for all featureclass layers. This is in addition to the ENVELOPE in the PROPERTIES section and the ENVELOPE for image layers. No ENVELOPE is included for acetate layers.
  <RESPONSE>
    <SERVICEINFO>
      <ENVIRONMENT>
        <SCREEN dpi="96"/>
      </ENVIRONMENT>
      <PROPERTIES>
      </PROPERTIES>
      </LAYERINFO>
        </FCLASS>
      </LAYERINFO>
    </SERVICEINFO>
  </RESPONSE>
</ARCXML>
Fields attribute
When fields is set to "true" in GET_SERVICE_INFO, fields in the shapefile or ArcSDE table are returned in FIELD in the SERVICEINFO response. If joined tables are used, they are included in the FIELD list. In the request below, fields is set to "true". The response includes FIELD information for the Countries featureclass layer.
GET_SERVICE_INFO request with fields:
  <REQUEST>
    <GET_SERVICE_INFO envelope="false" fields="true" renderer="false" extensions="false"/>
  </REQUEST>
</ARCXML>
SERVICEINFO response with FIELD:
  <RESPONSE>
    <SERVICEINFO>
      <ENVIRONMENT>
        <SCREEN dpi="96"/>
      </ENVIRONMENT>
      <PROPERTIES>
      </PROPERTIES>
      </LAYERINFO>
        </FCLASS>
    </SERVICEINFO>
  </RESPONSE>
</ARCXML>
Renderer attribute
When renderer is set to "true" in GET_SERVICE_INFO, all rendering information for a featureclass layer is included in the SERVICEINFO response. In the next example, renderer is set to "true". The response includes renderer information for the Countries featureclass layer. The returned information duplicates what is in the map configuration file.
GET_SERVICE_INFO request with renderer:
  <REQUEST>
    <GET_SERVICE_INFO envelope="false" fields="false" renderer="true" extensions="false"/>
  </REQUEST>
</ARCXML>
SERVICEINFO response with rendering:
  <RESPONSE>
    <SERVICEINFO>
      <ENVIRONMENT>
        <SCREEN dpi="96"/>
      </ENVIRONMENT>
      <PROPERTIES>
      </PROPERTIES>
      </LAYERINFO>
          <SIMPLERENDERER>
          </SIMPLERENDERER>
        </FCLASS>
      </LAYERINFO>
    </SERVICEINFO>
  </RESPONSE>
</ARCXML>
Extensions attribute
When extensions is set to "true" in GET_SERVICE_INFO, all extension information for a featureclass layer is included in the SERVICEINFO response. The three extension types are: In the request below, extensions is set to "true". The response includes three extensions for the Countries featureclass layer. The returned information duplicates what is in the map configuration file for "StoredQuery" and "Extract". The response for the "Geocode" extension does not include everything in the map configuration file, only GCSTYLE.
GET_SERVICE_INFO request with extensions:
  <REQUEST>
    <GET_SERVICE_INFO envelope="false" fields="false" renderer="false" extensions="true"/>
  </REQUEST>
</ARCXML>
SERVICEINFO response with extensions:
  <RESPONSE>
    <SERVICEINFO>
      <ENVIRONMENT>
        <SCREEN dpi="96"/>
      </ENVIRONMENT>
      <PROPERTIES>
      </PROPERTIES>
      </LAYERINFO>
            </OUTPUTFILE>
          </EXTRACTPARAMS>
        </EXTENSION>
        </EXTENSION>
          <STOREDQUERIES>
              </QUERY>
              </SQVAR>
            </STOREDQUERY>
          </STOREDQUERIES>
        </EXTENSION>
      </LAYERINFO>
    </SERVICEINFO>
  </RESPONSE>
</ARCXML>
Extensions attribute when GET_SERVICE_INFO is routed to the Geocode Server
In order to retrieve all information about a Geocode extension, the GET_SERVICE_INFO request must be routed to the Geocode Server. This routing information is contained in the URL sent to the ArcIMS site such as in the following example (all one line):
http://myComputer.domain.com/servlet/com.esri.esrimap.Esrimap?ClientVersion=3.1
      &ServiceName=myservice
      &CustomService=Geocode
      &Form=True&Encode=True
The GET_SERVICE_INFO request is the same as in the previous example. However, by routing the request to the Geocode Server, complete geocode extension information is returned. This information is similar to the information in the map configuration file. However, where GCFIELD is used in the map configuration file, GCINPUT is used in the SERVICEINFO response.
GET_SERVICE_INFO request with extensions routed to Geocode Server:
  <REQUEST>
  </REQUEST>
</ARCXML>
SERVICEINFO response with Geocode extension information:
  <RESPONSE>
    <SERVICEINFO>
      <ENVIRONMENT>
        <SCREEN dpi="96"/>
      </ENVIRONMENT>
      <LAYERINFO name="Countries" id="1" >
        <EXTENSION type="geocode">
          <GCSTYLE name="SingleField" >
            <GCINPUT id="KEYFIELD" type="text" label="KeyField" width="10" description="Any single field" />
          </GCSTYLE>
        </EXTENSION>
      </LAYERINFO>
    </SERVICEINFO>
  </RESPONSE>
</ARCXML>
Dpi attribute
One final attribute in GET_SERVICE_INFO is dpi (dots per inch). If a value is assigned to dpi in GET_SERVICE_INFO, this new value is returned in SCREEN in the SERVICEINFO response. Based on the new dpi, the minimum and maximum scales returned for scale-dependent elements, such as SCALEDEPENDENTRENDERER, LAYERINFO, LAYER, and OBJECT, are recalculated. The recalculation is useful in situations where the map configuration file was created on a machine with one dpi, but the client uses a different dpi.
If dpi is not included in GET_SERVICE_INFO, the dpi set in SCREEN in the map configuration file is used. If SCREEN is not included in the map configuration file, a default value of "96" is assumed.
The ArcIMS Java Viewers, ArcExplorer 4, and ArcMap send the dpi of the client in a GET_SERVICE_INFO request. The ArcIMS HTML Viewer does not send the dpi of the client. It uses the SCREEN dpi in the map configuration file or a default value of "96". Therefore, when using the ArcIMS HTML Viewer, the dpi of the client may not have the same dpi as the map configuration file. This means that scale dependencies will behave slightly different in the HTML Viewer.
The minimum and maximum scale values in LAYERINFO are listed as number of map units per pixel. In requests and the map configuration file, scales can be set using a relative scale ratio such as 1:24000. In this example, one meter equals 24000 meters or one inch equals 24000 inches.
Map units per pixel refers to the number of meters, feet, or decimal degrees represented by one pixel in a map. To convert from a relative scale to map units per pixel, the size of a pixel must first be calculated. The formula for finding the number of meters in a pixel is 0.0254 / dpi where: As an example of calculating pixel size, if the dpi is 96, the pixel size is 0.0254 / 96, or 0.000265 m.
Once the pixel size is known, the relative scale can be converted to map units per pixel:
  1. If the scale is in meters. To calculate the number of meters per pixel, take the relative scale and multiply by the pixel size (0.000265). For example, if the relative scale is 1:24000, then the number of meters per pixel is 24000 * 0.000265, or 6.36 meters.
  2. If the scale is in feet. Do the calculation for meters (#1). Multiply the result by 3.28 (the number of feet in a meter). For example, if the number of meters per pixel is 6.36, the number of feet per pixel is 6.36 * 3.28, or 20.86 feet.
  3. If the scale is in decimal degrees. For these calculations, the earth is assumed to be an exact circle with a circumference of 40030.174 km. One degree is 111.195 km (40030.174/360 degrees) or 111195 meters. To calculate the number of degrees, first do the calculation for meters (#1). Next, divide the result by 111195. For example, if the number of meters per pixel is 6.36, the number of degrees per pixel is 6.36 / 111195, or 0.0000571968.
If the maxscale for a LAYER is set to 1:12500000 in the map configuration file, and the dpi in GET_SERVICE_INFO is "96", then the maxscale for LAYERINFO is "3307.29828126323", or approximately 3307 meters per pixel.
<LAYERINFO type="featureclass" visible="true" name="Cities" id="4" maxscale="3307.29828126323">
  <FCLASS type="point"> </FCLASS>
</LAYERINFO>
If the dpi in GET_SERVICE_INFO is "120", then the maxscale for LAYERINFO is "2645.83862501058", or approximately 2645 meters per pixel.
<LAYERINFO type="featureclass" visible="true" name="Cities" id="4" maxscale="2645.83862501058">
</LAYERINFO>
The next examples show a GET_SERVICE_INFO request that includes dpi and the response.
GET_SERVICE_INFO request with dpi:
  <REQUEST>
    <GET_SERVICE_INFO dpi="192" envelope="false" fields="false" renderer="false" extensions="false"/>
  </REQUEST>
</ARCXML>
  <RESPONSE>
    <SERVICEINFO>
      <ENVIRONMENT>
        <SCREEN dpi="192"/>
      </ENVIRONMENT>
      <PROPERTIES>
      </PROPERTIES>
      </LAYERINFO>
        <FCLASS type="polygon"><FCLASS>
      </LAYERINFO>
    </SERVICEINFO>
  </RESPONSE>
</ARCXML>
