CHANGE_METADATA_ACCESS  Examples
Used in:  REQUEST
Servers:  Metadata (Publish)
Parent elements:  PUBLISH_METADATA
<CHANGE_METADATA_ACCESS Attribute Description Table
     docid ="string"
     private ="true | false"
     No Child Elements
</CHANGE_METADATA_ACCESS >
Bold: Attribute or child element is required.
Description:
Restrictions:
Notes:
Attribute Descriptions for CHANGE_METADATA_ACCESS:
Attribute Usage Back to Top
docid 1 String used to uniquely identify a document. The client used to publish the metadata is responsible for creating the document ID. This ID is automatically assigned when using ArcCatalog. If another client is used, GET_UUID can be used to request a valid ID. The format for an ID is the following:
{HHHHHHHH-HHHH-HHHH-HHHH-HHHHHHHHHHHH}
where H is a hexadecimal digit (0-9,a-f,A-F). The ID is limited to 38 characters.
private 2 Determines whether document is viewable for all users. Use "false" if the document is viewable by all users. Use "true" when the document is viewable only by the document owner.
Examples for CHANGE_METADATA_ACCESS:
Example 1: Back to Top
<?xml version="1.0" encoding="UTF-8" ?>
<ARCXML version="1.1">
  <REQUEST>
    <PUBLISH_METADATA>
      <CHANGE_METADATA_ACCESS docid="{C64D8F38-82B4-11D5-99C2-000086460FA0}" private="true" />
    </PUBLISH_METADATA>
  </REQUEST>
</ARCXML>
