Additional ArcXML Documents
In addition to the ArcXML Programmer's Reference Guide in WebHelp, the following related documents and files are also included with ArcIMS: On Windows, the ArcXML documents and files are installed during a typical setup and are located in the following directory: The files are also available from the ArcIMS Custom Setup. On the Installation Type screen, select Custom. On the next panel, the ArcIMS Components and Installation Directory screen, uncheck all components already checked, and check Documentation. Next, click Options and select only the ArcXML Programmer's Reference Guide. All the ArcXML documents are copied to the same ArcXML_Guide directory as listed above.
On UNIX, the DTD, the ArcXML Programmer's Reference Guide in WebHelp and PDF formats, and the shapefiles are found in the directory: The ArcXML documents are also available from ArcIMS Online: http://arcimsonline.esri.com.
