HASHLINESYMBOL  Examples
Used in:  CONFIG   REQUEST   RESPONSE
Parent elements:  EXACT   LINE   OTHER   POLYGON   RANGE   SIMPLERENDERER
<HASHLINESYMBOL Attribute Description Table
     antialiasing ="true | false"  [false]
     color ="0,0,0 - 255,255,255"  [0,0,0]
     interval ="0 - NNN"  [8]
     linethickness ="1 - NNN"  [1]
     overlap ="true | false"  [true]
     tickthickness ="1 - NNN"  [1]
     transparency ="0.0 - 1.0"  [1.0]
     type ="foreground | background"  [foreground]
     width ="1 - NNN"  [6]
     No child elements
</HASHLINESYMBOL >
Description:
Restrictions:
Notes:
Attribute Descriptions for HASHLINESYMBOL:
Attribute Usage Back to Top
antialiasing Used to make edges of labels and symbols smoother. When set to true, antialiasing is active. Note that the time to generate a map may significantly increase when antialiasing is turned on.
color Symbol color using RGB values.
interval Distance between railroad crosshatches in pixels.
linethickness Line thickness in pixels.
overlap Determines if labels can overlap this symbol. When true, labels can overlap. When false, labels will not overlap the symbol. If labels are not drawing as expected, check if overlap is set to false for this symbol or any other symbol in the MapService.
tickthickness Tick thickness in pixels.
transparency Value to set percentage of transparency. 1.0 is 0 percent transparent. 0.0 is 100 percent transparent.
type If type is foreground, the symbol draws as a railroad with the crosshash. If type is background, the symbol draws as a simple line without the crosshash.
width Width of the crosshash segments in pixels.
Examples for HASHLINESYMBOL:
Example 1: When in CONFIG or REQUEST. Back to Top
<?xml version="1.0" encoding="UTF-8"?>
<ARCXML version="1.1">
  <CONFIG>
    <ENVIRONMENT>
      <LOCALE country="US" language="en" variant="" />
      <UIFONT color="0,0,0" name="Arial" size="12" style="regular" />
      <SCREEN dpi="96" />
    </ENVIRONMENT>
    <MAP>
      <PROPERTIES>
         <ENVELOPE minx="-124.594842" miny="24.955227" maxx="-67.672764" maxy="49.596039" name="Initial_Extent" />
          <MAPUNITS units="decimal_degrees" />
      </PROPERTIES>
      <WORKSPACES>
         <SHAPEWORKSPACE name="shp_ws-0" directory="<path to USA ESRIDATA>"/>
      </WORKSPACES>
      <LAYER type="featureclass" name="ROADS" visible="true" id="1">
        <DATASET name="ROADS" type="line" workspace="shp_ws-0" />
        <SIMPLERENDERER>
          <HASHLINESYMBOL color="127,227,27" linethickness="8" tickthickness="8" transparency="0.5" interval="16" width="16" type="foreground" antialiasing="false" overlap="true" />
        </SIMPLERENDERER>
      </LAYER>
    </MAP>
  </CONFIG>
</ARCXML>
