RASTER_OTHER  Examples
Used in:  CONFIG
Parent elements:  RASTER_RENDERER
<RASTER_OTHER Attribute Description Table
     color ="0,0,0 - 255,255,255"  [0,0,0]
     label ="string"  ["Out of Range"]
     transparency ="0.0 - 1.0"  [1.0]
     No Child Elements
</RASTER_OTHER >
Description:
Restrictions:
Notes:
Attribute Descriptions for RASTER_OTHER:
Attribute Usage Back to Top
color Color using RGB values. Defines the color for all index values not previously defined.
label Description to be shown on legend. Valid with HTML Viewers only.
transparency Value to set percentage of transparency. 1.0 is 0 percent transparent. 0.0 is 100 percent transparent.
Examples for RASTER_OTHER:
Example 1: When in a map configuration file. Back to Top
<?xml version="1.0" encoding="UTF-8"?>
<ARCXML version="1.1">
  <CONFIG>
    <ENVIRONMENT>
      <LOCALE country="US" language="en" variant="" />
      <UIFONT color="0,0,0" name="Arial" size="12" style="regular" />
    </ENVIRONMENT>
    <MAP>
      <PROPERTIES>
        <ENVELOPE minx="0" miny="0" maxx="256" maxy="256" name="Initial_Extent" />
        <MAPUNITS units="decimal_degrees" />
      </PROPERTIES>
      <WORKSPACES>
        <SDEWORKSPACE name="sde_ws-0"  server="myserver" instance="port:5151" database="" user="WASHOE" encrypted="true" password="LXEMUR" />
      </WORKSPACES>
      <LAYER type="image" name="Land Use" visible="true" id="0">
        <DATASET name="WASHOE.BIT8_COLORMAP.IMAGE" workspace="sde_ws-0" />
        <RASTER_RENDERER>
          <RASTER_EXACT value="0" color="10,200,10" transparency="0.5"  label="Clouds"/>
          <RASTER_RANGE lower="1" upper="101" color="200,40,10" transparency="0.5"  equality="lower" label="Urban"/>
          <RASTER_RANGE transparency="1.0" lower="101" upper="255" color="255,255,10" equality="lower" label="Rural"/>
          <RASTER_OTHER transparency="0.0" label="Other"/>
        </RASTER_RENDERER>
      </LAYER>
    </MAP>
  </CONFIG>
</ARCXML>
