RASTER_RENDERER  Examples
Used in:  CONFIG
Parent elements:  LAYER
<RASTER_RENDERER >
     No Attributes
     (m) <RASTER_EXACT... />
     <RASTER_OTHER... />
     (m) <RASTER_RANGE... />
</RASTER_RENDERER >
(m):  Child element can be used multiple times.
Description:
Restrictions:
Notes:
Examples for RASTER_RENDERER:
Example 1: When in a map configuration file. Back to Top
<?xml version="1.0" encoding="UTF-8"?>
<ARCXML version="1.1">
  <CONFIG>
    <ENVIRONMENT>
      <LOCALE country="US" language="en" variant="" />
      <UIFONT color="0,0,0" name="Arial" size="12" style="regular" />
    </ENVIRONMENT>
    <MAP>
      <PROPERTIES>
        <ENVELOPE minx="0" miny="0" maxx="256" maxy="256" name="Initial_Extent" />
        <MAPUNITS units="decimal_degrees" />
      </PROPERTIES>
      <WORKSPACES>
        <SDEWORKSPACE name="sde_ws-0"  server="myserver" instance="port:5151" database="" user="WASHOE" encrypted="true" password="LXEMUR" />
      </WORKSPACES>
      <LAYER type="image" name="Land Use" visible="true" id="0">
        <DATASET name="WASHOE.BIT8_COLORMAP.IMAGE" workspace="sde_ws-0" />
        <RASTER_RENDERER>
          <RASTER_EXACT value="0" color="10,200,10" transparency="0.5"  label="Clouds"/>
          <RASTER_RANGE lower="1" upper="101" color="200,40,10" transparency="0.5"  equality="lower" label="Urban"/>
          <RASTER_RANGE transparency="1.0" lower="101" upper="255" color="255,255,10" equality="lower" label="Rural"/>
          <RASTER_OTHER transparency="0.0" label="Other"/>
        </RASTER_RENDERER>
      </LAYER>
    </MAP>
  </CONFIG>
</ARCXML>
