ArcXML
1.1 has several new elements and attributes. The new or changed features
are described below. Please pay close attention to anything marked with
an alert - . These items are specially marked due to fundamental
changes between ArcXML 1.0 (used with ArcIMS 3.0) and ArcXML 1.1.
New Documents and Examples
ArcXML 1.1 documentation includes an introductory section with comprehensive
explanations and additional examples on the following topics:
New Elements
The following elements are new in ArcXML 1.1.
ArcIMS Application Server Elements. These elements are used to communicate
with the ArcIMS Application Server rather than the ArcIMS Spatial Server.
Information on the following two elements is provided from the ArcIMS Application
Server but reported by the ArcIMS Spatial Server in the SERVICEINFO
response.
The following elements are included in map and viewer configuration files.
They provide support for internationalization.
The following elements are included as child elements to ENVIRONMENT, but
are used in configuration files, requests, and responses.
- SCREEN
- SEPARATORS. SEPARATORS identifies the characters
used between x- and y-coordinates and coordinate pairs. ArcXML 1.0 used
commas (x1,y1,x2,y2,...xn,yn). By default, ArcXML 1.1 uses a space between
x- and y-coordinates and a semicolon between coordinate pairs (x1 y1;x2
y2;...xn yn). SEPARATORS can be used in a map configuration file or request
to override the defaults. To be compatible with an ArcIMS 3.0 map configuration
file or request, use the following:
<ENVIRONMENT>:
<SEPARATORS cs=","
ts="," />
</ENVIRONMENT>
The following element is used in LEGEND support
and in IMAGE:
The following chart symbols have been added. Although chart symbols draw
on the map, no information about the chart symbols is displayed in the
legend. ArcIMS 3.1 does not support displaying chart values in the legend.
The following elements are used with the extract EXTENSION
in map configuration files.
Elements with New Attributes
The following elements have new attributes. Only the new attributes are
listed here:
Elements with Changed Attributes
had attributes modified in some way.
DATASET
- Attribute id is used rather than name
when fromlayer is included.
LAYER
- Attribute id is required in a map configuration
file. Each layer must have a unique ID.
LAYERDEF
- References to a layer must use the attribute
id.
NORTHARROW
- Attribute coord is now coords in
ArcXML 1.1. Also doublecheck the separators used with coords.
- The default angle is 0. In ArcIMS 3.0, the default
was 90. If you find the NORTHARROW pointing east in ArcIMS 3.1, reset
the angle to 0.
<NORTHARROW
type="4" coords="20 30" angle="0"/>
POINT in an acetate layer
<POINT coords="250
300">
SCALEBAR in an acetate layer
<SCALEBAR
coords="250 20" screenlength="300" mode="geodesic"
TEXT
<TEXT coords="100
100" label="Acetate layer" >
Removed Elements and Attributes
The following elements and attributes are no longer used in ArcXML 1.1.
- Attribute smoothedges has been removed from
BUFFER.
- Attribute type has been removed from LAYERDEF.
- Attribute name has been removed from TARGETLAYER.
- MAPUNITS is no longer
needed in GET_IMAGE or GET_EXTRACT
requests.
- FILTERDENSIFY is no longer used. Calculations are
done internally by the Spatial Server. The internal tolerance is width
/ 10.
Other Changes of Interest
- Acetate and image layers can be projected. Use COORDSYS.
- MAPUNITS is automatically
calculated by the ArcIMS Spatial Server when FEATURECOORDSYS
is present in the request or map configuration file.
- Layers will not project unless the layer includes
a *.prj file for shapefiles, a spatial references table for ArcSDE, or
COORDSYS.
- Acetate layer information is returned in SERVICEINFO.
- Dates can be used with SPATIALQUERY
and QUERY.
When using an ArcIMS HTML Viewer, ArcIMS Java Viewer, ArcExplorer 3,
or any other browser using the ArcIMS Servlet Connector, the following
elements are restricted.
These
restrictions can be lifted by setting the properties spatialServer.AllowRequestOutput
and spatialServer.AllowResponsePath to true in esrimap_prop. This
property file is found in the servlet engine directory. For more information
on the location of esrimap_prop and its properties, see the topic "Administering
the ArcIMS Servlet Connector" in the System Administration chapter
of the Using ArcIMS Help Contents.
These restrictions apply only when the ArcIMS Servlet Connector is
used. They do not apply to the ActiveX or ColdFusion Connectors or to
other connectors using the ArcIMS Application Server Link.
