Using Configuration Files
Introduction
Configuration files are used to define a map. There are three types of configuration files: The following sections cover configuration files in detail. The first section discusses map configuration files. The second section covers viewer configuration files. The third section reviews default.axl. A final section provides a summary review of the similarities and differences among the three configuration file types.
Map Configuration Files
Map configuration files are used as input to MapServices. All information in a map configuration file provides a default set of instructions for map properties and rendering. Requests can override information in the MapService properties, but if the request does not include the element, then the default MapService properties prevail. The diagram below shows the flow for creating a MapService using a map configuration file as input.
Framework of a map configuration file
A map configuration file can be divided into several sections. The following example shows the basic framework.
Framework of a map configuration file:
<?xml version="1.0" encoding="UTF-8"?>
<ARCXML version="1.1">
  <CONFIG>
    <ENVIRONMENT>...</ENVIRONMENT>
    <MAP>
      <PROPERTIES>...</PROPERTIES>
      <WORKSPACES>...</WORKSPACES>
      <LAYER>...</LAYER>
    </MAP>
  </CONFIG>
</ARCXML>
A map configuration file includes:
ARCXML and the prolog
The first line of an ArcXML statement is the prolog. All ArcXML 1.1 statements are required to use a standard prolog that includes the XML version and encoding. The XML version is 1.0. Encoding in ArcXML 1.1 is UTF8. UTF-8 and UTF8 can be used interchangeably in map configuration files, but ArcIMS Author writes configuration files using UTF-8.
After the prolog, all ArcXML statements begin and end with ARCXML. This element is required, and the version number is 1.1.
Prolog and ARCXML:
<ARCXML>
</ARCXML>
CONFIG, ENVIRONMENT, and MAP
A map configuration file distinguishes itself from a REQUEST or RESPONSE by the CONFIG element. For more information on the relationship between map configuration files, requests, and responses, see Introduction to ArcXML.
The only child elements to CONFIG in a map configuration file are ENVIRONMENT and MAP.
CONFIG, ENVIRONMENT, and MAP:
  <CONFIG>
    <MAP>...</MAP>
  </CONFIG>
</ARCXML>
ENVIRONMENT is used to set up information about the environment used in the MapService. Once the environment is established, clients in one locale can access a MapService created in another locale. Child elements of ENVIRONMENT include the following:
ENVIRONMENT and its child elements:
<ENVIRONMENT>
  <LOCALE language="en" country="US" />
  <UIFONT name="Arial" color="0,0,0" size="12" style="regular" />
  <SEPARATORS cs=" " ts=";"/>
  <SCREEN dpi="96"/>
</ENVIRONMENT>
The element MAP contains all the instructions for generating a map. This includes the map
MAP and its child elements:
<MAP>
  <LAYER>...</LAYER>
</MAP>
The PROPERTIES, WORKSPACES, and LAYER elements are discussed in detail in the next sections.
MAP: PROPERTIES
PROPERTIES provides the framework for defining properties about a MapService. The child element ENVELOPE is required but all other child elements are optional. The child elements shown in the following example are used in both Image and Feature MapServices.
PROPERTIES and its child elements for both Feature and Image MapServices:
<PROPERTIES>
  <ENVELOPE minx="-105.594842" miny="-49.955227" maxx="75.672764" maxy="83.596039" name="Initial_Extent" />
  <MAPUNITS units="decimal_degrees" />
  <BACKGROUND... />
  <FEATURECOORDSYS id="54008" />
  <FILTERCOORDSYS id="54008" />
</PROPERTIES>
The following child elements are valid only with Image MapServices and are more commonly used in requests than in a map configuration file:
PROPERTIES and its child elements valid only with Image MapServices (in bold):
<PROPERTIES>
<LEGEND... />
  <OUTPUT... />
</PROPERTIES>
MAP: WORKSPACES
WORKSPACES specifies the location of all the data used in the map configuration file. All data locations must be visible to any computer hosting MapServices. Each workspace must have a unique reference name. Valid WORKSPACES in map configuration files are:
Valid WORKSPACES in a map configuration file:
<WORKSPACES>
  <SHAPEWORKSPACE name="shp_ws-0" directory="c:\ESRIDATA"/>
  <IMAGEWORKSPACE name="jai_ws-1" directory="c:\ESRIDATA"/>
  <SDEWORKSPACE name="sde_ws-2" server="zephyr" instance="port:5150" database="" user="washoe" encrypted="true" password="LXEMUR" />
</WORKSPACES>
MAP: LAYER
LAYER is the parent element for defining a map layer. Attributes cannot be overridden by a request. The following attributes are required: The following attributes are optional:
Sample LAYER with attributes:
<LAYER type="featureclass" name="CITIES" minscale="1:24000" maxscale="1:100000" visible="true" id="2"> ... </LAYER>
MAP: LAYER child elements
A LAYER used in a map configuration file has several child elements. The purpose of these elements is to identify the data source and to render the data.
LAYER with child elements:
  <DATASET name="Cities_Robinson" type="polygon" workspace="shp_ws-0" />
  <DENSIFY tolerance="10000" />
  <COORDSYS id="54030" />
  <SPATIALQUERY where="population > 1000000" />
  <SIMPLERENDERER>
    <SIMPLEPOLYGONSYMBOL filltransparency="1.0" fillcolor="27,127,127" />
  </SIMPLERENDERER>
</LAYER>
The types of child elements can be divided into several groups: DATASET, projection elements, query elements, EXTENSION elements, and renderer and symbol elements.
Sample map configuration file
The following map configuration file uses many of the elements discussed above.
Example map configuration file:
  <CONFIG>
    <ENVIRONMENT>
      <LOCALE country="US" language="en" variant="" />
      <UIFONT color="0,0,0" name="Arial" size="12" style="regular" />
      <SCREEN dpi="96" />
    </ENVIRONMENT>
    <MAP>
      <PROPERTIES>
        <ENVELOPE minx="-135.0" miny="-64.0" maxx="84.0" maxy="86.0" name="Initial_Extent" />
      </PROPERTIES>
      <WORKSPACES>
        <SHAPEWORKSPACE name="shp_ws-4" directory="<path to WORLD ESRIDATA>" />
      </WORKSPACES>
      <LAYER type="featureclass" name="Oceans" visible="true" id="0">
        <DATASET name="WORLD30" type="polygon" workspace="shp_ws-4" />
        <SIMPLERENDERER>
          <SIMPLEPOLYGONSYMBOL fillcolor="51,153,255"/>
        </SIMPLERENDERER>
      </LAYER>
      <LAYER type="featureclass" name="Countries" visible="true" id="1">
        <DATASET name="country" type="polygon" workspace="shp_ws-4" />
        <GROUPRENDERER>
          <VALUEMAPRENDERER lookupfield="POP_CNTRY">
            <RANGE lower="0" upper="50000000" label="Less than 50000000">
              <SIMPLEPOLYGONSYMBOL fillcolor="255,255,0"/>
            </RANGE>
            <RANGE lower="50000001" upper="100000000" label="50000000 - 100000000">
              <SIMPLEPOLYGONSYMBOL fillcolor="255,170,0" />
            </RANGE>
            <RANGE lower="100000001" upper="1281008319" label="Greater than 100000000">
              <SIMPLEPOLYGONSYMBOL fillcolor="255,85,0"/>
            </RANGE>
          </VALUEMAPRENDERER>
          <SCALEDEPENDENTRENDERER upper="1:35000000">
            <SIMPLELABELRENDERER field="CNTRY_NAME">
              <TEXTSYMBOL antialiasing="true" font="Arial Bold" fontstyle="bold" fontsize="12" />
            </SIMPLELABELRENDERER>
          </SCALEDEPENDENTRENDERER>
        </GROUPRENDERER>
      </LAYER>
    </MAP>
  </CONFIG>
</ARCXML>
The map configuration file contains information on the locale, map properties, workspaces, and how each layer should be drawn. In the ENVIRONMENT section, the LOCALE country and language are the "US" and "En". For UIFONT, the default font of Arial is used, and the default dpi in SCREEN is 96. The PROPERTIES elements show that the MAPUNITS are in decimal degrees and the ENVELOPE coordinates are -135.0,-64.0 and 84.0,86.0. In the WORKSPACES section, one SHAPEWORKSPACE is included for shapefiles in the WORLD ESRIDATA data set.
The map contains two layers:
  1. Ocean. This layer contains one renderer, SIMPLERENDERER. The layer has a solid blue fill as described in SIMPLEPOLYGONSYMBOL.
  2. Countries. This layer contains several renderers. A VALUEMAPRENDERER is used to define how each country should be colored based on population. Countries with a population less than 50 million are yellow, those with a population between 50 and 100 million are light orange, and those with a population greater than 100 million are dark orange. A SCALEDEPENDENTRENDERER is used for labeling. The labels do not turn on until the scale is less than 1:35000000.
The following figure shows a map drawn based on the instructions in the map configuration file.
If the initial extent is changed so the scale is less than 1:35000000, the map zooms in enough so that labels for countries appear.
Change in initial ENVELOPE:
  <CONFIG>
    <MAP>
      <PROPERTIES>
        <ENVELOPE minx="-13.0" miny="36.0" maxx="34.0" maxy="69.0" name="Initial_Extent" />
      </PROPERTIES>
      <LAYER>...</LAYER>
    </MAP>
  </CONFIG>
</ARCXML>
The following figure shows a map at a scale of about 1:35000000 and includes labels.
Viewer Configuration Files
Viewer configuration files are the output when a file is saved in ArcExplorer 3 or the ArcIMS Java Viewers. The diagram below provides a more detailed flow of the process to create a viewer configuration file:
Framework of a viewer configuration file
The framework of a viewer configuration file is similar to a map configuration file. The framework includes the CONFIG, ENVIRONMENT, and MAP elements. These elements function the same in both map and viewer configuration files. PROPERTIES is fundamentally the same as well, but only ENVELOPE and MAPUNITS are included.
In many cases a viewer configuration file can look just like a map configuration file. This is true when only local data sources are included in the file and the only WORKSPACES present are SHAPEWORKSPACE, IMAGEWORKSPACE, and SDEWORKSPACE.
Viewer configuration files can contain additional elements that are not in a map configuration file. The following example shows some of these elements.
Example viewer configuration file:
  <CONFIG>
    <ENVIRONMENT>
      <SCREEN dpi="96" />
    </ENVIRONMENT>
    <MAP>
      <PROPERTIES>
        <ENVELOPE minx="-178.0" miny="12.89" maxx="-68.0" maxy="83.59" name="Initial_Extent" />
      </PROPERTIES>
      <WORKSPACES>
        <IMAGESERVERWORKSPACE name="mapper_ws-6" url="http://mymachine.domain.com/servlet/com.esri.esrimap.Esrimap" service="background" />
        <FEATURESERVERWORKSPACE name="ifs_ws-7" url="http://mymachine.domain.com/servlet/com.esri.esrimap.Esrimap" service="states" />
        <AVIMSWORKSPACE name="av_ws-6" url="http://mymachine.domain.com/servlet/com.esri.esrimap.Esrimap" view="Roads" map="roads21204240" />
        <MOIMSWORKSPACE name="mo_ws-4" url="http://mymachine.domain.com/scripts/esrimap.dll" service="GPS_Points" />
        <SHAPEWORKSPACE name="shp_ws-8" directory="<path to CANADA ESRIDATA" />
      </WORKSPACES>
      <LAYER type="image" name="Background" visible="true" id="0">
        <DATASET name="background" type="image" workspace="mapper_ws-6" />
      </LAYER>
      <LAYER type="featureclass" name="States" visible="true" id="1">
        <DATASET name="2" type="polygon" workspace="ifs_ws-7" />
        <SIMPLERENDERER>
          <SIMPLEPOLYGONSYMBOL boundarytransparency="1.0" filltransparency="1.0" fillcolor="255,255,153" boundarycaptype="round" />
        </SIMPLERENDERER>
      </LAYER>
      <LAYER type="featureclass" name="Provinces" visible="true" id="2">
        <DATASET name="province" type="polygon" workspace="shp_ws-8" />
        <SIMPLERENDERER>
          <SIMPLEPOLYGONSYMBOL boundarytransparency="1.0" filltransparency="1.0" fillcolor="127,27,27" boundarycaptype="round" />
        </SIMPLERENDERER>
      </LAYER>
      <LAYER type="image" name="Roads" visible="true" id="3">
        <DATASET name="mymachine.domain.com:roads21204240:Roads" type="image" workspace="av_ws-6" />
        <IMAGEPROPERTIES transparency="0.80" />
      </LAYER>
      <LAYER type="image" name="GPS Points" visible="true" id="4">
        <DATASET name="mymachine.domain.com:GPS_Points" type="image" workspace="mo_ws-4" />
      </LAYER>
    </MAP>
    <OVERVIEWMAP backgroundcolor="255,255,255" framefillcolor="255,0,0,80" frameoutlinecolor="255,0,0" zoomfactor="4.0">
      <LAYERDEF name="States" />
      <LAYERDEF name="Provinces" />
    </OVERVIEWMAP>
    <SCALEBAR backcolor="212,208,200" fontcolor="0,0,0" mapunits="decimal_degrees" scaleunits="feet" screenunits="inches" />
  </CONFIG>
</ARCXML>
The additional elements are: Each of these elements is described below.
IMAGESERVERWORKSPACE is used in the WORKSPACES section for Image MapService layers.
Using IMAGESERVERWORKSPACE:
  <CONFIG>
    <MAP>
      <WORKSPACES>
      </WORKSPACES>
      </LAYER>
    </MAP>
    <OVERVIEWMAP>...</OVERVIEWMAP>
    <SCALEBAR ... />
  </CONFIG>
</ARCXML>
References to an Image MapService in IMAGESERVERWORKSPACE are made in the service attribute. In the above example, the name of the Image MapService is "background". The url attribute gives the location of the Image MapService. In the example, the location is "http://mymachine.domain.com". In addition to the domain, the location of the ArcIMS servlet connector is also included. This information is the same for all ArcIMS sites and is "/servlet/com.esri.esrimap.Esrimap".
For the Image MapService layer, references to the MapService are made in DATASET. The attribute name is the same as IMAGESERVERWORKSPACE service. In this example, the name is "background". The DATASET type is always "image". Image MapService layers are always treated as one layer in a viewer configuration file, and the sublayers are not included.
FEATURESERVERWORKSPACE is used in the WORKSPACES section for Feature MapService layers.
Using FEATURESERVERWORKSPACE:
  <CONFIG>
    <MAP>
      <WORKSPACES>
      </WORKSPACES>
        <SIMPLERENDERER>
        </SIMPLERENDERER>
      </LAYER>
    </MAP>
    <SCALEBAR ... />
  </CONFIG>
</ARCXML>
References to a Feature MapService in FEATURESERVERWORKSPACE are made in the service attribute. In the above example, the name of the Feature MapService is "states". The url attribute is used the same way as with Image MapService. In the example, the location of the ArcIMS Servlet Connector is "http://mymachine.domain.com/servlet/com.esri.esrimap.Esrimap".
Each layer in a Feature MapService is treated as a separate layer, and each layer can be accessed individually. In the above example, only one layer of a Feature MapService has been accessed.
For a Feature MapService layer, DATASET is always included, and rendering information is usually included. In DATASET, the attribute type is set to the same type as in the Feature MapService. In the above example the type is "polygon". The attribute name is set to the LAYER id in the Feature MapService. In this example, the LAYER id in the Feature MapService is "3", and therefore the DATASET name in the viewer configuration file is "3". The following examples highlight the differences between the map configuration file used as input to the Feature MapService and the output in the viewer configuration file.
Map configuration file used in the Feature MapService:
<LAYER type="featureclass" name="States" visible="true" id="3">
  <DATASET name="STATES" type="polygon" workspace="shp_ws-1" />
  <SIMPLERENDERER>
  </SIMPLERENDERER>
</LAYER>
Viewer configuration file:
  <DATASET name="3" type="polygon" workspace="ifs_ws-7" />
  <SIMPLERENDERER>
  </SIMPLERENDERER>
</LAYER>
In the map configuration file, the LAYER id is "3", which is unique within the map configuration file, and the DATASET name is "STATES" and refers to a shapefile in the "shp_ws-1" workspace. In the viewer configuration file, the LAYER id is "1", which is unique within the viewer configuration file. The DATASET name is "3", which refers to the LAYER id in the map configuration file. The workspace reference is "ifs_ws-7", which refers to the workspace for the Feature MapService. The rest of the layer information in the map and viewer configuration files is identical.
When using ArcExplorer 3 and when permission is given in the ArcIMS Java Viewers, the layer rendering can be changed using the Layer Properties Dialog. In the following example, the States layer is rendered in light yellow by default.
Default viewer configuration file:
  <SIMPLERENDERER>
  </SIMPLERENDERER>
</LAYER>
If a user changes the rendering, this new information is stored in the viewer configuration file. The change is local and does not affect the Feature MapService. In the next example, the rendering is changed from light yellow to various colors based on the population of each state.
After layer rendering has been changed in the viewer configuration file:
  <VALUEMAPRENDERER lookupfield="POP1999">
    <RANGE lower="482025" upper="11351422" label="Less than 11351422">
      <SIMPLEPOLYGONSYMBOL boundarytransparency="1.0" filltransparency="1.0" fillcolor="255,255,0" boundarycaptype="round" />
    </RANGE>
    <RANGE lower="11351422" upper="22220818" label="11351422 - 22220818">
      <SIMPLEPOLYGONSYMBOL boundarytransparency="1.0" filltransparency="1.0" fillcolor="255,170,0" boundarycaptype="round" />
    </RANGE>
    <RANGE lower="22220818" upper="33090215" label="22220818 - 33090215">
      <SIMPLEPOLYGONSYMBOL boundarytransparency="1.0" filltransparency="1.0" fillcolor="255,85,0" boundarycaptype="round" />
    </RANGE>
  </VALUEMAPRENDERER>
</LAYER>
Remember that in a viewer configuration file, any rendering changes remain local to the machine that the configuration file resides on. The change does not affect the Feature MapService.
AVIMSWORKSPACE
AVIMSWORKSPACE is used in the WORKSPACES section to reference a map generated from ArcView IMS.
Using AVIMSWORKSPACE:
  <CONFIG>
    <MAP>
      <WORKSPACES>
      </WORKSPACES>
      </LAYER>
    </MAP>
    <SCALEBAR ... />
  </CONFIG>
</ARCXML>
AVIMSWOKSPACE references a map in ArcView IMS using the attributes view and map. The values for these attributes are the ArcView IMS MapName and ViewName, respectively, and can be found in the applet HTML file of an ArcView IMS MapCafé web site. For example, if the web site is named "MySite", open "MySiteapplet.html". Look for the parameters MapName and ViewName. For more information on using ArcView IMS with ArcIMS, see Appendix B of Using ArcIMS. As with other WORKSPACES types, the url attribute references the ArcIMS servlet connector.
The DATASET name for the layer references the machine and domain, MapName, and ViewName separated by colons (:). In the above example, the DATASET name is "mymachine.domain.com:roads21204240:Roads".
MOIMSWORKSPACE
MOIMSWORKSPACE is used in the WORKSPACES section to reference an ArcExplorer-enabled map generated from MapObjects IMS.
Using MOIMSWORKSPACE:
  <CONFIG>
    <MAP>
      <WORKSPACES>
      </WORKSPACES>
      </LAYER>
    </MAP>
    <SCALEBAR ... />
  </CONFIG>
</ARCXML>
References to an ArcExplorer-enabled MapObjects IMS map in MOIMSWORKSPACE are made in the service attribute. In the above example, the name of the map is "GPS_Points". The url attribute gives the location of esrimap.dll located on the machine with MapObjects IMS. ArcExplorer-enabled maps do not work with the ArcIMS Servlet Connector. However, the ArcIMS Servlet Connector can be used with regular MapObjects IMS sites.
The DATASET name references the machine and domain and the MapObjects IMS map name separated by a colon (:). In the above example, the DATASET name is "mymachine.domain.com:GPS_Points".
SHAPEWORKSPACE, IMAGEWORKSPACE, and SDEWORKSPACE are used when local data is referenced in the viewer configuration file. These WORKSPACES elements reference data exactly the same way as in a map configuration file.
OVERVIEWMAP and SCALEBAR
OVERVIEWMAP and SCALEBAR are client configuration elements and add an overview map or scale bar, respectively. Both elements are saved when using ArcExplorer 3 or an ArcIMS Java Standard Viewer. Only SCALEBAR is saved in an ArcIMS Java Custom Viewer even if an overview map is present. Also, the ArcIMS Java Custom Viewer ignores these elements when a viewer configuration file is read into the viewer.
If an overview map or scale bar are present when a viewer configuration file is saved, the OVERVIEW and SCALEBAR elements are included.
Using OVERVIEWMAP and SCALEBAR:
  <CONFIG>
    <MAP>...</MAP>
    <OVERVIEWMAP backgroundcolor="255,255,255" framefillcolor="255,0,0,80" frameoutlinecolor="255,0,0" zoomfactor="4.0"<>
      <LAYERDEF name="Oceans" />
    <LAYERDEF name="Countries" />
  </OVERVIEWMAP>
  </CONFIG>
</ARCXML>
If these two elements are included in a map configuration file, they are ignored.
Default.axl: A Special Viewer Configuration File
Default.axl is a special viewer configuration file that is output by ArcIMS Designer when an ArcIMS Java Viewer is created. The diagram below shows the process to create default.axl:
Framework of default.axl
Default.axl uses a subset of elements normally found in a viewer configuration file. Its primary purpose is to load MapService layers specified during the ArcIMS Designer process.
Example default.axl file:
  <CONFIG>
    <MAP>
      <PROPERTIES>
        <ENVELOPE minx="-180.0" miny="-90.0" maxx="180.0" maxy="90.0" name="Initial_Extent" />
      </PROPERTIES>
      <WORKSPACES>
        <IMAGESERVERWORKSPACE name="mapper_ws-6" url="http://mycomputer.domain.com/servlet/com.esri.esrimap.Esrimap" service="background" />
        <FEATURESERVERWORKSPACE name="ifs_ws-7" url="http://mycomputer.domain.com/servlet/com.esri.esrimap.Esrimap" service="World" />
      </WORKSPACES>
      <LAYER type="image" name="background" visible="true" id="0">
      </LAYER>
        <DATASET name="0" type="polygon" workspace="ifs_ws-7" />
      </LAYER>
      <LAYER type="featureclass" name="United States" visible="true" id="2">
        <DATASET name="1" type="polygon" workspace="ifs_ws-7" />
      </LAYER>
    </MAP>
  </CONFIG>
</ARCXML>
Only elements that are needed to load the MapServices are included. The principal similarities and differences between default.axl and a viewer configuration file are
Relationship between Feature MapServices and default.axl
When ArcIMS Designer creates default.axl and a Feature MapService is included, one LAYER is included in default.axl for every LAYER in the Feature MapService. Since no rendering is included in default.axl, the rendering defined in the MapService is what is used by the ArcIMS Java Viewers. Any changes to the rendering in the MapService are immediately reflected in the ArcIMS Java Viewers.
Caution is needed when adding or deleting layers in a MapService. If a layer is added to a MapService but not to default.axl, the ArcIMS Java Viewer will not display the new layer. If a layer is deleted from a MapService but not default.axl, an error message appears in the ArcIMS Java Viewer because a layer referenced in default.axl cannot be found in the MapService. In summary, if a layer is added or deleted in a MapService, it should be added or deleted in default.axl.
Comparing Different CONFIG Files
The table below summarizes the similarities and differences between map configuration files, viewer configuration files, and default.axl.
  Map Config Viewer Config Default.axl
Primary purpose Used as input to MapServices Saves current map and viewer configuration on the client Used to load MapServices in an ArcIMS Java Viewer
Created by ArcIMS Author or XML Editor ArcExplorer 3 or ArcIMS Java Viewers ArcIMS Designer
File is located On server On client On server
Data sources Local network only and must be accessible by ArcIMS Spatial Server MapServices and local network on client MapServices only
Valid workspaces SHAPEWORKSPACE, IMAGEWORKSPACE, SDEWORKSPACE IMAGESERVERWORKSPACE, FEATURESERVERWORKSPACE, AVIMSWORKSPACE, MOIMSWORKSPACE, SHAPEWORKSPACE, IMAGEWORKSPACE, SDEWORKSPACE IMAGESERVERWORKSPACE, FEATURESERVERWORKSPACE, AVIMSWORKSPACE, MOIMSWORKSPACE
